Hello! 3 days ago my Ryzen 5 3600 stopped booting into Windows for an unknown reason after running well and without any problem for 3 days. I can still go into bios(30-60*C), but whenever I try to boot Windows it just restarts in a loop. I switched it from an AMD Athlon 3000g and I'm wondering if it's a problem with the CPU or the PSU. I should mention that it had a bent pin, but I easily fixed it. Also when I switch to Athlon,windows boots.
Here is a clip
https://quickshare.samsungcloud.com/bFyy9ilNie1L
https://quickshare.samsungcloud.com/v1xa6OUeJoTg
Specs:
CPU: Ryzen 5 3600
CPU cooler: id-cooling se-213v2
Motherboard: a320m-s2h
Ram: 8gb ddr4 2666mhz
SSD/HDD: 250gb
GPU: rx550 2gb (will change later)
PSU: 550w RPC 55000AB (PWPS-055000A-BU01A) (will change later)
Also, can you recommend a decent PSU for this build instead of RX550 I'll upgrade to RX580.(Under 65$)
OS: Win10
Monitor: asus
THANK YOU!
https://linustechtips.com/topic/1529400-cpu-or-psu-problem/
I coudnt  get into any windows menu before. Only the windows icon would appear then it would restart over and over again
Here are the clips
https://quickshare.samsungcloud.com/w2JxDzdgojqW
https://quickshare.samsungcloud.com/yRM7ICzF06GY (When I try installing windows it does a loop aswell)
And after I installed windows with my Athlon, after switching CPUs it still reboted like before.
https://linustechtips.com/topic/1529400-cpu-or-psu-problem/#findComment-16121875
