Budget (including currency): 600EUR
Country: Estonia
Games, programs or workloads that it will be used for: General tasks, chrome, etc
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Jusy need a prebuild PC for 600 with a pretty case, thats what my girlfriend wants and i have no idea what to suggest her. Help
https://linustechtips.com/topic/1529356-pc-for-general-tasks/
"Pretty" is subjective.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1529356-pc-for-general-tasks/#findComment-16121541
Country: Estonia
Pre-built? You can build the pc yourself and it is not that hard.
This video should explain everything.
If not, it is totally ok to buy a pre-built PC.
Best I could find was this:
https://www.amazon.de/High-end-GeForce-DDR4-RAM-3200MHz-Warranty/dp/B0BW4KHGGQ/ref=sr_1_13_sspa?crid=1KZTJWNUF0AGI&th=1
If you change your mind to build your own pc, you can go for these parts:
https://de.pcpartpicker.com/list/B6jvn6
All that is left is motherboard, but I could not find a one for that price range or with WiFi.
https://linustechtips.com/topic/1529356-pc-for-general-tasks/#findComment-16121570
I know building a PC is not hard, I've done it but my girl doesnt want to do that. Shes lazy and just wants plug and run PC
Thanks for the feedback tho
https://linustechtips.com/topic/1529356-pc-for-general-tasks/#findComment-16121576
I mean build it for her? You aren't finding a not shitbox that doesnt rip you off that is pink
https://linustechtips.com/topic/1529356-pc-for-general-tasks/#findComment-16121581
Closest thing you can do is find a white pc and paint it or put stickers on it prob. Unless you build it yourself.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1529356-pc-for-general-tasks/#findComment-16121587
