Hello guys I have the problem for 5 days I try every discored and forms no one help:c
my pc shut down in middle of browsing then vga led appear.
if I leave the pc for 8h in cold rom it post for 3 min.
now after I wake up i run it then it worked show windows for the first time in days but frezz then led agine.
gpu:6750xt
psu:core reactor 650w
pls help
https://linustechtips.com/topic/1529251-need-help-with-gpu/
gpu:6750xt
pls help
Agree with @ChieriOnTop, make sure the fans are spinning, on both CPU AND GPU.
I'd do a CMOS clear first, see if the problems persists, then do a clean install of drivers, and if it is not software, try reseating CPU, GPU, and RAM one by one.
https://linustechtips.com/topic/1529251-need-help-with-gpu/#findComment-16120610
I did all that nothing change.
it might be cable cuz I had it b4 add second cable(not using pigtail work fine for 2 weeks)
https://linustechtips.com/topic/1529251-need-help-with-gpu/#findComment-16120618
