Hey, I would like to replace my thermal paste, but I am not that experienced with PC building. A friend of mine handled it for me previously (the only thing I have ever done is install a RAM stick – I know, not very impressive). However, my friend is currently quite busy, so I'll have to do it myself this time. The part that worries me a bit is having to remove the old thermal paste. I slightly dampened a piece of cloth with some cleaning alcohol (I'm not sure if this is the best method, but I saw it somewhere). I'm just concerned that the cloth might be too wet, and I could end up damaging components. So, I was wondering, what is the safest way to remove the thermal paste? Any help is greatly appreciated.
https://linustechtips.com/topic/1529211-how-to-replace-thermal-paste-safely/
Is there a particular reason why you want to replace the thermal paste?
Typically, I use isopropyl alcohol pads to kinda grab the paste. I then use tissues to clean and follow up with a Q-tip in 91% isopropyl alcohol to ensure there is no residue remaining. Do this on both the IHS of the CPU and the heatsink. Make sure it's completely dry and then apply thermal paste and put back together again.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
