Every time I start my computer It starts up normally and gets to the windows loading screen, then crashes right after that and never gets to the login screen...
This is the info I get:
Stop: 0x00000116
Nvlddmkm.Sys
Datestamp 5315b408
I looked up that it's graphics related so I uninstalled my GPU drivers and I was able to launch without safe mode, but when I reinstalled the drivers and restarted, it crashed again.
Any solution to this?
https://linustechtips.com/topic/152919-bsod-help/
Stop: 0x00000116
Nvlddmkm.Sys
Datestamp 5315b408
Try using the last driver that you KNOW worked if you are using something like a beta driver.
https://linustechtips.com/topic/152919-bsod-help/#findComment-2042321
Wasn't using a beta driver when this happened, and the driver has been fine for the past months... I'm using a beta driver now and it seems better... It crashed once and I got the error STOP: 0x00000119 but Its working fine now... I'm logged in and everything. I'll post again if it crashes.
https://linustechtips.com/topic/152919-bsod-help/#findComment-2042350
What card are you using? It may just A: if its an old card that you have had for years it may just be giving out or if its new you Mayans to try RMAing it.
https://linustechtips.com/topic/152919-bsod-help/#findComment-2042370
Stop: 0x00000116
Nvlddmkm.Sys
Datestamp 5315b408
Firstly, your system specs would be nice and also any OC if created. Is this a recent problem or is this a new build and it just doesn't boot properly? Is you RAM compatible with your motherboard?......Help me help you.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/152919-bsod-help/#findComment-2044397
wrong subforum, this should have gone in troubleshooting
i wish you good luck in your battles let the troubleshooting work in your favor!
Edit: if you know the card isn't faulty, try wiping all detected graphics drivers and install the latest, there is a program for it, but i'm not at my computer right now so i couldn't tell you.
Build: Sister's new build |CPU i5 2500k|MOBO MSI h61m-p23 b3|PSU Rosewill 850w  |RAM 4GB 1333|GPU Radeon HD 6950 2GB OCedition|HDD 500GB 7200|HDD 500GB 7200|CASE Rosewill R5|Status online
Build: Digital Vengeance|CPU i7 4790k 4.8GHz 1.33V|MOBO MSI z97-Gaming 7|PSU Seasonic Xseries 850w|RAM 16GB G.skill sniper 2133|GPU Dual R9 290s|SSD 256GB Neutron|SSD 240GB|HDD 2TB 7200|CASE Fractal Design Define R5|Status online
https://linustechtips.com/topic/152919-bsod-help/#findComment-2044733
Here's my specs:
i7-2600k @ 4.2GHz
Sabertooth z77 Motherboard
GTX 660Ti x2
16GB Corsair vengeance 1600MHz
TX850M PSU
Its not a new build... Its been working fine for months and months... I recently downloaded Arma 3 and tried to run it with SLI... this is basically the first time I've used my second graphics card because all the other games I've been playing don't support SLI. I was testing it out and when I launch without SLI on everything runs fine... but when I turn SLI on I get artifacts at the main menu and it crashes after a few seconds freezing my whole system. Not sure if my second GPU is just broken.... I'm gunna try testing just the second GPU in a minute see if it crashes.
https://linustechtips.com/topic/152919-bsod-help/#findComment-2046801
Here's my specs:
i7-2600k @ 4.2GHz
GTX 660Ti x2
TX850M PSU
Right...now i can help you. I suspect the problem is with your OC and ARMA3. you may need to add some voltage to your OC. Go up by 0.010v and see if you get to boot if not try 0.010v more and see. If your GPU is OCed by you and not factory OC then you may need to lower your GPU's OC. You can also try to clear you CMOS. Since it is Steam you are using you can also try "verify integrity of game cache" and see if it helps.
https://linustechtips.com/topic/152919-bsod-help/#findComment-2046838
Fairly sure its not my OC because my system is booting fine and Arma 3 is running fine on one GPU without SLI, also my GPU isn't overclocked past the factory OC. I verified the game cache and it said all the files were verified successfully. I'm thinking the problem is either with my second GPU or Arma3's SLI support. Any way I can test my second GPU? I remember I ran Heaven 4.0 with it on a while ago and it passed it perfectly.... so not really sure if its my GPU or not.
Edit: My CPU is actually overclocked to 4.6GHz not 4.2. But its stable.
https://linustechtips.com/topic/152919-bsod-help/#findComment-2046885
Starting to think its my second GPU... I just tried to run the Heaven 4.0 Benchmark with SLI enabled and it crashed. Then I disabled SLI ran it again and it made it through the whole thing with no errors. This mean my second GPU is toast or anything else I can do to fix it?
https://linustechtips.com/topic/152919-bsod-help/#findComment-2046951
If it is under warranty you can RMA it but other than that you cannot do anything to fix it. It can also be the SLI driver that maybe corrupted. Have you tried replacing the second GPU with the first and also using each GPU separately and running the Heaven 4.0 on both?
https://linustechtips.com/topic/152919-bsod-help/#findComment-2047022
Ill do that now... see if it works
Also, its still under warranty... only a few months old
https://linustechtips.com/topic/152919-bsod-help/#findComment-2047032
Yea, its broken... I just tried to run Heaven 4.0 with the second GPU and it started showing artifacts then crashed after a few seconds... I guess I should just RMA it then?
https://linustechtips.com/topic/152919-bsod-help/#findComment-2047087
