So i have a Sapphire nitro RX580 8gb i picked up for cheap $70CAD from a miner, and it was used as a mining card, and in turn to have my investment last just a bit longer, i wanna replace all the thermal pads/paste. But i have no idea on what pads to use and where to get them, does anyone have some suggestions
thanks in advance
Edited by Alex..B
https://linustechtips.com/topic/1528989-thermal-pads/
46 minutes ago, Alex..B said:
So i have a RX580 i picked up for cheap $70CAD from a miner, and it was used as a mining card, and in turn to have my investment last just a bit longer, i wanna replace all the thermal pads/paste. But i have no idea on what pads to use and where to get them, does anyone have some suggestions
thanks in advance
List the brand & model of the GPU as well, since different brands and/or models may use different thickness.
You know, so people can give you a more informed answer.
Refresh before you reply
https://linustechtips.com/topic/1528989-thermal-pads/#findComment-16118461
The thickness varies so again, refer to other people's finding on your SPECIFIC BOARD, but in general I like Gelid Thermal Pads with Arctic MX-6. Decent bang for the buck and applies like normal.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1528989-thermal-pads/#findComment-16119042
thanks in advance
Might be helpful for you.
And no, I don't know for sure whether or not it's the correct size
Read the video description as well.
https://linustechtips.com/topic/1528989-thermal-pads/#findComment-16119124
