I have problem since I build the pc after running for a while about 1-2 week it never start so I always try with same cable but different locations.it worked couple of time the third time is now never work with the same configuration so I add the second 8pin cable I have work for 2-3week then today it shutdown and never start with vga led on. If let it for 1-2 hours the gpu fan work but still no post with led. Anyone have the same problem what is the best solution Ty
1more update I leave the pc for 4 unplug after I turn it show bios for 5 sec then start the same problem agine
My spect is
R5 5600
Msi a pro b550
6750xt Msi
Core reactor 650w gold
https://linustechtips.com/topic/1528928-need-help-with-gpu/
Was the card running with only a single power cable plugged in? Is that what I've read?
Do you have the option of trying a different card? Or that card in a different PC?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1528928-need-help-with-gpu/#findComment-16117858
I did all the cable option 1with dual head and 2cable.
I try 970 every thing work.
I wake up then try it agine open to bios but Efi enable after that enable it restart then same loop
https://linustechtips.com/topic/1528928-need-help-with-gpu/#findComment-16117876
Ok, you might need to uninstall the Nvidia drivers, use Display Driver Uninstaller DDU after that to remove the leftovers and then retry.
Do you have the latest Bios version on the motherboard? Might need to update the bios too.
https://linustechtips.com/topic/1528928-need-help-with-gpu/#findComment-16117883
I would like to do that but I can’t see anything no post bios page or anything just vga led
https://linustechtips.com/topic/1528928-need-help-with-gpu/#findComment-16117887
With the 970?
https://linustechtips.com/topic/1528928-need-help-with-gpu/#findComment-16117901
7 minutes ago, Abdulrhman 276 said:
No with 6750 to narrow it down fan spinning but after running for 5min nothing and after restarting no spin
im sure the card pcie and gpu work but there is something missing
For some reason, I find your posts hard to read/understand.
Might I suggest using interpunctions (periods, commas, etc.) and a tool like Grammarly (a free browser addon)?
https://linustechtips.com/topic/1528928-need-help-with-gpu/#findComment-16117930
Lol sry I will try my.
I had this problem b4 I just add another cable and it work.
now with 2 cable connected to the gpu it was running perfectly for 3-2 weeks.
yesterday when I was browsing it shutdown then vga led appeared with no post.
https://linustechtips.com/topic/1528928-need-help-with-gpu/#findComment-16117956
