I’ve been having some annoyances with USB transfer speeds and bottlenecks.
I’m a videographer and every time I have to offload and backup my footage it’s a pain. I always backup to 3 drives but I feel like I’m constantly running into bottlenecks. My SD cards max out at 250MB/s, my card reader is USB 3.2 gen 2x2 plugged into a correlating port, drive 1 is an internal NVME, drive 2 is an external SanDisk Extreme Pro, and drive 3 is my NAS which is connected via 1 gig Ethernet (that’s a bottleneck I’m aware of).
when backing up files I will transfer from the SD card to all 3 drives simultaneously. In my mind that should mean that I’m getting around 250MB/s on drives 1 and 2, and around 100MB/s on drive 3. However, I usually get about 65 to 100MB/s on all three drives.
Is there a reason the speed is so bottlenecked? And is there anything I can do to solve it?
https://linustechtips.com/topic/1528569-usb-transfer-speed/
Well it's pretty simple, the SD card doesn't know it has to copy all the same files to different locations, so it has to make 3 different copies, basically cutting your speeds into 1/3.
Would be better to Copy to the PC and from there to the NAS and External disc simultaneously.
EDIT: You can also use Robocopy, that could speed up copying because it is multi threaded while windows copy is not. I am assuming you copy hundres of files only a few MB in size.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1528569-usb-transfer-speed/#findComment-16114442
Unfortunately I have to copy from the SD card each time to fight file corruption. If a file was corrupted while transferring to drive 1 and then I copied that file onto drives 2 and 3 the file would be corrupted on all three drives. But if I copy fresh from the SD card each time that risk is lessened.
How does Robocopy work and where can I find it? My files are usually between 350MB and 3GB per file. And I’m shooting about 150GB at most on one card.
https://linustechtips.com/topic/1528569-usb-transfer-speed/#findComment-16116174
