dark rock pro 3
Go to solution Solved by nicehat,
yea, let the thermal grease cure and really melt for the heatsink to shine. Give it a couple of days
So I just got my dark rock pro 3 and I upgraded from a stock CPU fan. Im still getting the same temps which is about 61 degrees Celsius. Is this supposed to happen since I just installed it or is there something wrong.
CPU: i7 3930k 4.5ghz CPU COOLER: Be quiet dark rock pro 3 MOBO: MSIx79a-GD45 PLUS RAM: G-Skill 16GB  GPU: MSI 780 TF  Storage: 2tb seagate and 60 GB OCZ ssd PSU: corsair CS750M
:D
https://linustechtips.com/topic/152840-dark-rock-pro-3/
AMD FX-8350 @ 4.7Ghz when gaming | MSI 990FXA-GD80 v2 | Swiftech H220 | Sapphire Radeon HD 7950  +  XFX Radeon 7950 | 8 Gigs of Crucial Ballistix Tracers | 140 GB Raptor X | 1 TB WD Blue | 250 GB Samsung Pro SSD | 120 GB Samsung SSD | 750 Watt Antec HCG PSU | Corsair C70 Mil Green
https://linustechtips.com/topic/152840-dark-rock-pro-3/#findComment-2041463
Thanks man
:D
https://linustechtips.com/topic/152840-dark-rock-pro-3/#findComment-2041515
