Budget (including currency): 15K INR
Country: India
Games, programs or workloads that it will be used for: Mostly Genshin Impact and maybe some Witcher 3. I also stream a few days a month (1080p)
Other details:
This is my current setup:
  • Ryzen 5 3600
  • MSI B450 Tomahawk Max
  • 16 GB Corsair Vengeance LPX DDR4 3200MHz CL16
  • INNO3D iCHILL X3 RED GeForce RTX 3060 Ti
  • Gigabyte GP-P850GM power supply
  • Samsung 970 Evo Plus 500GB (M.2) + WD Blue 250GB SSD
  • Zebronics Zeb-Enyo Chassis
  • 2x DeepCool CF120C fans
  • Acer Nitro QG221Q 21.5" monitor
  • Lenovo Ideapad M100 mouse
  • HP GK320 keyboard
  • TP-Link Nano AC600 USB Wi-Fi Adapter
The setup works fine, but tends to slow down a bit when opening a bunch of browser tabs or if I try to play a video on Twitch and play Genshin at the same time.
The motherboard may be damaged (I don't know for sure) since I can't upgrade the RAM. If I add another stick of RAM:
  1. In dual channel, it doesn't boot at all and the RAM red light turns on.
  2. In the wrong slots, it boots up, but shows the warning message.
Only RAM slots 1 and 2 seem to work - when I insert RAM in slots 3 or 4, refuses to boot up/post.
Not sure which part of my setup's causing this - the processor, the motherboard or the wifi adapter.
Honestly, any recommendations would be really helpful.
https://linustechtips.com/topic/1528315-need-help-troubleshootingupgrading-my-setup/
Update the bios if that doesn't solve the issue then it's definitely a hardware problem maybe the cpu maybe the ram slots maybe the motherboard. The slowing down problem is either you need more ram or the cpu is is fully or mostly utilised, check task manager for catching the issue. If you need more ram it's easy buy 2 16gb sticks if it's cpu then you can't do much, try closing the apps you aren't using or don't open too much tabs lol
Wait you can buy the 5600 for cpu but you gotta update the bios for that too
Edited by that_potato_guy
Forgot the cpu
The only you can do is try to isolate the pieces to figure which is faulty. Put ram in the slots that work and run "mem test"
Not sure how to test the CPU and the motherboard without changing parts
One thing I do with my browser(firefox) I use an extension called "simple tab groups" which I can specify for each group that when they are not used dump the data from the RAM to save space. So look something similar for your browser.
My Daily/Gaming Setup:
  • CPU
    Intel i7-13700k
  • Motherboard
    Gigabyte Z690 Gaming X DDR4
  • RAM
    Kingston Fury 32GB (2x16GB) DDR4 3600MHz CL 16 Renegade RGB
  • GPU
    Asus TUF Gaming 3070 OC
  • Case
    Fractal Torrent Compact
  • Storage
    Kingston Fury Renegade M.2 1TB SSD (BOOT)
    Corsair MP400 4TB m.2 (Game Library...)
  • PSU
    Corsair RM850X 80+ gold
  • Cooling
    NH-D15
  • Keyboard
    Logitech g915 TKL
  • Mouse
    Logitech G pro X superlight
  • Sound
    Behringer UM2
    UA Apollo Duo X (I noticed I don't have a Thunderbolt port after purchase 😢)
    Behringer UMC1820 (main)
  • Operating System
    Win 11 pro
My Home Server:
OS: TrueNAS Scale
CPU: i9900k
Ram: Corsair Vengeance LPX Black 32GB (2x16GB) 3200MHz  CL16
Motherboard: Asus gaming z390-f (6sata connectors)
Cooler: Corsair Hydro H80i v2 120mm AIO
PSU: Corsair 600w 80+ bronze
Storage: 3*4TB Seagate Ironwolf HHD
Boot: 2* M.2 NVMe Gen 3 500GB
Case: Cheap fractal case with HDD mounts
Thanks for the suggestions.
I updated the bios recently to 7C02v3H (from link)
Checked inserting each single RAM stick I have into each of the 4 available slots:
  1. Slots 1 and 2 work - BIOS and Windows boot (single stick)
  2. Slots 3 and 4 refuse to even load BIOS for some reason. (single stick)
  3. RAM in Slots 1 and 2 (non-dual channel) loads BIOS and both sticks are recognized, but throws up the "This is not optimized" warning message
  4. RAM in Slots 1+3 or 2+4 (dual channel) does not load BIOS.
XMP is turned on now, but I tested all this before it was turned on.
Not sure how to check if the slot itself is faulty on the motherboard, or if it's one of those "CPU screws are too tight" moments (I did losen them by about a half-turn. but nothing changed)
@Parsivan Not sure what you mean by "mem test". I use Waterfox browser - this is what it usually sits at when I'm not playing:image.thumb.png.a376985b2af3dd069f958dc304fa4c0a.png
If I am to upgrade, I'm guessing I'll have to change the motherboard first or the CPU too?
MemTest86 - Official Site of the x86 and ARM Memory Testing Tool
It is used to diagnose problems with ram...thought it might help.
16GB is now the new 8GB. 8GB is too low for a gaming setup. If you want to upgrade, go for 32GB then you will not be needing to upgrade for long time. future proof 🙂
  • CPU
    Intel i7-13700k
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
    NH-D15
  • Keyboard
    Logitech g915 TKL
  • Mouse
  • Sound
    Behringer UM2
  • Operating System
    Win 11 pro
My Home Server:
OS: TrueNAS Scale
CPU: i9900k
