Monitor has "dirty screen effect"
Solved by Andrewtst,
Dirty screen can't be fix, that is screen uniformity issue and that may vary between units.
If it is too serious, you should immediately request for exchange, else that it is, and no worried it is not a sign of bad things.
Here is the rtings review - MSI Optix MAG274QRF-QD Review - RTINGS.com
This units got not bad uniformity and probably you are unlucky getting one that is not that good.
If the dirty screen is sudden happen at OLED, then that is different issue and pixel cleaning can clear it.
No way to clear for IPS, VA and any display panel others than OLED.
