Please help, weird audio issue.
Solved by ImWilly,
51 minutes ago, kanye east said:I plug it straight into my monitor(VIA aux port) but the sound is really low, can get slightly loud but not very loud.
How can I make it so the audio sounds the same?
Try to check on your monitor setting, usually via pressing the buttons on the monitor
Since your monitor have 3,5mm jack plug, it normally has audio/sound setting as well
If it already on the max output, try to check on volume mixer on the Windows, especially in output device (usually named of your monitor, then followed by High Definition Audio Device) to see the volume setting
