4 minutes ago, Tiutaus said:
Hello, i am planning to build a gaming pc and i need a little help to know if i should change something and if this build is a stupid idea.
These are Europe prices so generally bit more expensive than american
(Budget 2200 euros not including windows)Screenshot2023-08-13214040.thumb.png.8ab45b544aa6ae1982e1a8e1d17d0ea6.png
Looks decent but if it's just gaming then go for this
PCPartPicker Part List: https://de.pcpartpicker.com/list/r6T3Cd
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€415.41 @ LK-Webservices)
CPU Cooler: Deepcool AK620 DIGITAL 68.99 CFM CPU Cooler  (€86.98 @ Alternate)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  (€235.90 @ Alza)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  (€106.71 @ Computeruniverse)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€128.99 @ Amazon Deutschland)
Video Card: XFX Speedster MERC 310 Black Edition Radeon RX 7900 XTX 24 GB Video Card  (€979.90 @ Alza)
Case: Deepcool CC560 ARGB ATX Mid Tower Case  (€64.90 @ Alza)
Power Supply: Thermaltake Toughpower GF A3 - TT Premium Edition 1050 W 80+ Gold Certified Fully Modular ATX Power Supply  (€147.05 @ Amazon Deutschland)
Total: €2165.84
Generated by PCPartPicker 2023-08-13 20:48 CEST+0200
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1525950-pc-build-help/#findComment-16076422
CPU Cooler: Deepcool AG500 BK ARGB 67.88 CFM CPU Cooler  (€49.98 @ Alternate)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (€181.13 @ Mindfactory)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€119.89 @ Alternate)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€99.90 @ Alternate)
Case: Phanteks Eclipse G300A (3 Fan) ATX Mid Tower Case  (€77.89 @ Caseking)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€129.00 @ ARLT)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  (€3.59 @ Aquatuning)
Total: €2056.69
Generated by PCPartPicker 2023-08-14 05:54 CEST+0200
free compression
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1525950-pc-build-help/#findComment-16077056
If you are going to put an XFX 7900XTX into the Corsair 4000X case (I think it's the same dimensions as the 4000D Airflow) you should know that the card will not fit into the case with the included XFX anti-sag bracket attached if you have the 3 fans installed in the front of the case. Due to the angled shape of the anti-sag bracket it is about 3-4 cm too long and hits the front fans. You might want to look at a larger case (Corsair 5000 series) or use a different anti-sag mount in the 4000 series.
I just build a 7800x3d 7900XTX in a Corsair 4000D Airflow system last week and was not pleased to find out the total length of the GPU didn't include the extra length of the anti-sag bracket (it is a solid bracket though)
https://linustechtips.com/topic/1525950-pc-build-help/#findComment-16078083
