41 minutes ago, Kkiiii said:
I would wa t a nvidia grapichs card and mybe 64 Gb of ram
and can there be water cold cpu cooler
cant you articulate why the gpu has to be made by nvidia , or what you need 64gb of ram for , or why the cpu cannot be air cooled.
https://linustechtips.com/topic/1525762-pc-build-help/#findComment-16075133
I want nvidia couse of ray tracing i want more ram so my pc is faster idk water cooled cpu seems better had a water cooled before and i think i dknt want to change it so yea can you pls send some parts 😀
https://linustechtips.com/topic/1525762-pc-build-help/#findComment-16075264
