CPU always overheating.
Go to solution Solved by TeraSeraph,
Get a contact plate from ThermalRight.
I've got the i9-13900KF and no matter what I do It's always overheating, around 45-55 while idle and 90-100 while gaming, I've upgraded to a bigger case for better airflow (7000D), upgraded to a better cooler (Deepcool LT720), installed better thermal paste (thermal grizzly kryonaut), even tried undervolting and underclocking my CPU but no matter what I do I still get the same temperatures. The screws on my cooler wont tighten anymore so I don't think its an issue w/ my cooler not being installed correctly, I've just got no idea what to do.
https://linustechtips.com/topic/1525358-cpu-always-overheating/
is it throttling ?
HWiNFO64 is good at showing that.
Is it currently undervolted/underclocked ? how much ?
RPM from Pump and Fans at full load ?
Oh...do you know about this  :
? (there are also cheaper alternatives available)
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16072620
1 hour ago, leclod said:
is it throttling ?
Oh...do you know about this  : (there are cheaper alternatives available)
Yeah it always throttles, goes down to like 4500 MHz clock speed at the mid to high 90s, It's not currently undervolted/underclocked but when it was it was 5400MHz and 1.3V. All fans & pump are set to run at max speed 24/7.
1 hour ago, hotelrwanda said:
Did you remove the sticker on the cooler's contact area
Some people forget to do that
There was a plastic cover and I removed it.
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16072641
3 minutes ago, mistxoli said:
-snip-
Your ambient? Also, have you try remounting it? Your mounting might be wack, apply even pressure in a cross pattern and only go hand tight, a quarter turn extra max.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16073245
Is one of the AIO tubes hotter than the other?
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16073247
I don't know what ambient is, but I've tried remounting the CPU cooler twice, the last time I made sure to make sure everything is as tight as possible and even added a bit more thermal paste but I doesn't seem to have made a difference.
They feel the same.
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16073257
Why don't you have it undervolted now ?
Also, I found another method for undervolting (following a tutorial) Now I'm on a "CPU Lite Load Mode 9 instead of Mode 12 curve" which got me even lower. (might be MSI specific)
Edited by leclod
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16073281
Just now, TeraSeraph said:
Is the pump making noises? If you pinch the tube can you feel the water flowing through? Do you have the AIO hooked to your Pump header?
I'm pretty sure the pump is making noises, its quite hard to press down on the tubes but I do think I can feel water flowing through, the AIO is connected to the designated AIO pump header.
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16073295
When I had it undervolted I had a worse cooler so I thought I'd be able to run it at its normal speed once I got this cooler.
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16073298
Undervolted not underclocked. There's no reason to not undervolt if your undervolt is stable. I think.
Edited by leclod
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16073302
if the legs are mounted to the underside of the cooler, and the bolts are so tight u cant make em tighter with ur hands ... u might have a bad unit... clogged or somthing
but i would try a "out side the case  run"
like this:
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16073315
When installing the contact plate I realise that I had been using the wrong spacers the entire time, I now get 30 degrees idle and 50 degrees gaming.
https://linustechtips.com/topic/1525358-cpu-always-overheating/#findComment-16076439
