Im new to building a pc and I'm having alot of trouble doing so  because I don't know if I have picked the wrong stuff or what so ever my budget is $1400 AUD
I was wondering if this is a good build? http://au.pcpartpicker.com/user/RatchetHoee/saved/4FlG
for this cpu get a z87 mobo
CPU: Intel core i7-4770 --- CPU Cooler: Corsair H105 --- GPU: Asus Geforce GTX 970 Strix --- MB: Asus Maximus VI Hero --- RAM: Corsair Vengeance Pro 16GB
Case: Corsair Obsidian 750D --- PSU: Corsair AX860i --- SSD: Seagate 120GB --- HDD: Seagate 2TB + Toshiba 1TB --- ODD: Asus External DVD-R
Keyboard: Razer Blackwidow 2013 Ultimate --- Mouse: Logitech G602 --- Mousepad: Corsair Vengeance MM600 --- Monitor: LG 29UM65
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2035895
i would reacomend getting pro or home premium.
I dont reacomend getting this Microsoft Windows 7 Ultimate SP1 (OEM) (64-bit)
Although i have it, i got it for free.
oh okay I just put that in because I didn't know if I needed it when I started the PC up after building
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2035910
It's alright, but a 750TI and an i5 for gaming isn't really that great.
You would be better off with even an FX6300 and a higher end GPU, so go for an 8320 on 990FX platform with a higher end GPU. (this makes sense in US and EU market, idk about Aus though since you guys are weird)
Consider a cheaper case, blowing 100$ on a fancy shell that does the same thing as a 50$ one doesn't really seem like the best use of money on a budget.
Use the trial version of Windows until you scape up enough pesos for Windows 8 (note not 7). You don't really lose that much functionality for running a trial version indefinitely.
Error: 410
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2035915
i feel like you should be getting a better graphics card for how much u are spending maybe get win 7 home premium and spend the extra $$$ on a better graphics card. something similar to this http://au.pcpartpicker.com/p/3Kbo2 oh and also if you are going to be using the disc to install your operating system you might want to get an optical drive
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2035947
U need to get a gtx 760 at minimum, ditch the ultimate windows 7, get windows 7 home edition. Check with your school if you can get free version for windows 7. In US we do.
Get a z87 motherboard for your build
u would also need a ssd, I highly recommend it.
U can get Corsair 200r case instead, a perfect case for a decent price, u will save around 40 bucks there.
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2035965
Changed it up a bit assuming you're not overclocking.
The monitor I'd personally choose, you can keep the original one you picked if you'd like.
edit : http://au.pcpartpicker.com/p/3KbLn
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2035971
Here you go, if you add the O/S later when you have the cash, this should absolutely destroy. 8.1 OEM in Aus paper is only a bit over 100$ IIRC. Crossfire ready to boot.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($189.00 @ PCCaseGear)
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00 @ Mwave Australia)
Motherboard:  Asus M5A99X EVO R2.0 ATX AM3+ Motherboard  ($159.00 @ PCCaseGear)
Memory:  G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($95.00 @ PCCaseGear)
Storage:  Kingston SSDNow V300 Series 60GB 2.5" Solid State Disk  ($63.00 @ Mwave Australia)
Storage:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($67.00 @ CPL Online)
Video Card:  Sapphire Radeon R9 280X 3GB Vapor-X Video Card  ($399.00 @ Mwave Australia)
Case:  BitFenix Shinobi Window ATX Mid Tower Case  ($75.00 @ CPL Online)
Power Supply:  EVGA SuperNOVA NEX750B BRONZE 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($125.00 @ Mwave Australia)
Monitor:  Asus VE248H 24.0" Monitor  ($188.00 @ CPL Online)
Total: $1399.00
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-15 10:54 EST+1000)
Error: 410
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2035979
Total: $1399.00
whats the difference between AMD and intel?
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2035997
An Intel CPU will usually beat an AMD CPU by a few frames (when they're both high enough, it's negligible)
If you play MMOs or older games that aren't multi-core aware, the AMD CPU will struggle. In newer games the results are more similar though.
The GPU is more of a concern, when working with lower budgets it's better to put more of the money into a better GPU where 8/10 times it will have a greater impact than the difference between a 4670k and 8320.
and obviously the AMD chip uses more power.
Error: 410
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2036017
If you don't want Windows 8.1, you can go Windows 7, its the same price.
PCPartPicker part list: http://au.pcpartpicker.com/p/3KlRK
Price breakdown by merchant: http://au.pcpartpicker.com/p/3KlRK/by_merchant/
Benchmarks: http://au.pcpartpicker.com/p/3KlRK/benchmarks/
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($249.00 @ PCCaseGear)
Motherboard: ASRock H87M Pro4 Micro ATX LGA1150 Motherboard  ($102.00 @ CPL Online)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($95.00 @ CPL Online)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  ($82.00 @ Mwave Australia)
Video Card: Gigabyte Radeon R9 270X 2GB WINDFORCE Video Card  ($249.00 @ PCCaseGear)
Case: Corsair 200R ATX Mid Tower Case  ($85.00 @ PCCaseGear)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($105.00 @ Mwave Australia)
Optical Drive: LG GH24NSB0 DVD/CD Writer  ($21.00 @ Mwave Australia)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($115.00 @ CPL Online)
Monitor: AOC E2260SWDN 60Hz 21.5" Monitor  ($135.00 @ Mwave Australia)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($44.00 @ CPL Online)
Total: $1388.00
(Generated by PCPartPicker 2014-05-15 16:46 EST+1000)
Gaming/Editing PC: AMD FX-8350 | CM Seidon 120V Liquid Cooler | Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard | G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600| Gigabyte GeForce GTX 770 2GB WINDFORCE | PNY XLR8 240GB SSD | Seagate Barracuda 2TB HDD | Corsair 600W ATX Semi-Modular PSU | Thermaltake Chaser A71 | LG 25UM64-S 25.0" 2560 x 1080 Display | CM Storm Devastator Gaming Keyboard & Mouse
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2037205
link.  Supposed to be really inexpensive and other people have had success with it.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/152419-1400-gaming-pc-help/#findComment-2037237
