5 minutes ago, Jigachad said:
I am looking at getting a SSUPD Meshlicious for a ITX build. Will it fit with my XFX SPEEDSTER MERC 310 AMD Radeon™ RX 7900 XT Black Edition? Going off what I've read on SSUPD's website it seems that it will fit. Just want a extra opinion or two.
Well, the case say this: Full length GPU: 4 slots mode up to 336mm length(GPU Baffle not included), 346mm length(GPU Baffle included )
So a max of 346mm and the XFX 7900 XT MERC BLACK is 344mm. Its a tight fit but yes, that should do.
https://linustechtips.com/topic/1522064-will-my-gpu-fit/#findComment-16050969
