Finally got time to put together my new pc, and I got it to boot right away. I did get a fTPM currupted on start up. Not sure what that was but I pressed Y as some people had said on the internet and it went to the BIOS no problem.
The temps where 26C at idle in the bios, something I think is more then fine, but there was a trickling sound from the aio that I think might be air. I did kinda angle the case a little without going crazy and it was some difference but not much. Should I try turning it upside down or laying it flat? Should I avoid running it until it is fixed. The AIO is the silent loop 2 from be quiet, and does come with some water to top the loop up, but from what I read in the manual it was more for 2+ years down the line. Also I have had AIO without this issue several years.
https://linustechtips.com/topic/1522042-air-in-loop/
There isn't room for mounting the AIo in the top so the front is the only option.
edit: not sure why the file isn't showing, hope I fixed it this time
pc
https://linustechtips.com/topic/1522042-air-in-loop/#findComment-16050822
Running it is the fix. The air will settle somewhere out of the way of the coolant eventually.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1522042-air-in-loop/#findComment-16050876
