Upgrading CPU in SFX build need advice on what/if is worth the upgrade.
18 minutes ago, ImServs said:My computer is used for gaming, streaming and video editing in my free time, but when i work, I use it for 3D modeling, 3D rendering, and 3D/2D game development in Unreal Engine, specifically UE5 recently, with Raytracing from time to time. I want a CPU upgrade to my rig to help with render times and performance within the live editors of UE5, Blender, Maya, Substance Suite, and DaVinci Resolve. But im not sure what CPU upgrade would show drastic improvement if any at all is even worth. What CPU would/could be worth the upgrade?
(Highlighted the parts that would mostly affect the upgrade)
My current build:
Case: Dan Case C4-SFXPSU: Corsair SF750 Plat
CPU: i7-12700K
CPU Cooler: Noctua DH-D12L
GPU: RTX Rog Strix 3090 OC
RAM: 64gb (2x32gb) TridentZ RGB 6000Mhz
Mobo: ASRock Z790 iTX/TB4Storage: WD Black SN850X 1tb (OS and application drive)
Storage: x2 Samsung 970 EVO plus 2tb (gaming and file storage)
There are only 3 (arguably 4) that are improvements at all:
12900K
13700K
13900K
and maybe the 13600K.
So only the 12900K and 13900K would be substantial upgrades. The 13900K would be the only worthwhile one IMO. But you'll most likely thermal throttle it in that setup. So your gains may be marginal, hard to know exactly.
Okay, so it may not be hard to know exactly Thanks @Agall
