will be a "bottelneck"
Go to solution Solved by filpo,
1 minute ago, Gold_Glitch said:
what's the strongest gpu I can get without feeling a huge bottleneck
At 1440p? Probably a 6800 xt (maybe) or a 3070 ti. But these both would defo require a good 750w/850w psu like this SeaSonic FOCUS 850 W 80+ Gold Certified Semi-modular ATX Power Supply (FOCUS GM-850) - PCPartPicker
or this Thermaltake Toughpower GF1 ARGB 850 W 80+ Gold Certified Fully Modular ATX Power Supply (PS-TPD-0850F3FAGU-1) - PCPartPicker
Just now, Gold_Glitch said:
do i need a buy  +700w psu
You probably will. What country are you in again?
Some recommendations would be these
Thermaltake Smart BM2 750 W 80+ Bronze Certified Semi-modular ATX Power Supply (PS-SPD-0750MNFABU-1) - PCPartPicker
Cooler Master MWE Bronze V2 700 W 80+ Bronze Certified ATX Power Supply (MPE-7001-ACAAB-US) - PCPartPicker
Cooler Master XG850 850 W 80+ Platinum Certified Fully Modular ATX Power Supply (MPG-8501-AFBAP-US) - PCPartPicker
from gtx1070ti  mybe to 6700xt 6750xt rtx 3070
for 1440p gaming (pubg scum hunt bf2042 etc)
no it won't since the 3600 is a decent enough cpu and at 1440p it'll be fine.
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1521497-will-be-a-bottelneck/#findComment-16047061
croatia
is it worth going from 1070 ti to 6700 etc.
can the 1070ti run games 1440p medium details +60fps
can i go whit 600-650w or do i need a +750w
https://linustechtips.com/topic/1521497-will-be-a-bottelneck/#findComment-16047069
for the 3070 I say go for 750. But for the two amd cards you can go with 650
I'd still consider this 750w from thermaltake for 80 euros Thermaltake Smart BM2 750 W 80+ Bronze Certified Semi-modular ATX Power Supply (PS-SPD-0750MNFABU-1) - PCPartPicker
no
yes, there's about a 60 percent uplift on average
Total: £1040.95
https://linustechtips.com/topic/1521497-will-be-a-bottelneck/#findComment-16047080
no
https://linustechtips.com/topic/1521497-will-be-a-bottelneck/#findComment-16047085
Total: £1040.95
https://linustechtips.com/topic/1521497-will-be-a-bottelneck/#findComment-16047090
1 minute ago, filpo said:
tnx "kid" fir help 😏
https://linustechtips.com/topic/1521497-will-be-a-bottelneck/#findComment-16047091
