Pc specs:
Cpu: ryzen 5 2600
Gpu: msi gaming x gtx 1070
Mb: Asrock b450m steel legend Psu: Seasonic s12ii 620w bronze / CM mwe 650w bronze v2 (brand new)
Ram: Corsair vengeance 16gb 3200mhz(8*2)
Monitor: msi optix mag241c
So i was playing Genshin impact all temps was under limit gpu temps where under 75c then suddenly im pc power off. I tried to open it and nothing was happening like it was not connected to any power source. The thing is i can power on my pc after removing gpu but as i have ryzen cpu without inbuilt graphic it won't boot if i put my gpu back on my pc would behave as it was not connected to power
Thing i have tried:
1. Putting gpu on different motherboard slot
2. Resetting the ram
3.Changing psu as i have problem with seasonic psu in the past and got a gud deal on cooler master mwe 650 bronze v2 psu but even after using that i got the same result
Any suggestions would really be appreciated 馃檹
https://linustechtips.com/topic/1521465-need-help-plz/
14 hours ago, PotatoMasher69 said:
Thing i have tried:
If you havent, reset CMOS. Had similar issue with my R5 2600 build.
Press quote聽to get a response聽from someone! | Check people's edited posts!聽|聽Be specific!聽| Trans Rights
https://linustechtips.com/topic/1521465-need-help-plz/#findComment-16047891
