Is there any advantage to using a 5G Pocket WiFi / 5G CPE Modem vs a 5G smartphone's tethering / hotspot?
Solved by Alex Atkin UK,
8 minutes ago, Bismut said:I would assume the mobile hotspot to be a tad better and have reception even when the phone does not, since that is its only purpose. Not to a significant degree, though.
But I would get a 5G thingy with an RJ45 jack as well as a WiFi hotspot to have more redundancy as well as a more stable connection via wire, at least in theory.
The portable ones typically have worse reception than a phone and may not support all the technologies to get the best speed, the fixed ones way way better than a phone and support more connected devices.
