Country: NZ
Games, programs or workloads that it will be used for: GPU/CPU Intensive video-games, VR, minor video-editing.
Motherboard: Asus ROG Strix B760-F
CPU: I7-13700K
GPU: MSI RTX 4070Ti Suprim X
Aio: Corsair iCUE H170i Elite Capellix XT
Storage: x2 M.2
RAM: 32GB DDR5 5600Mhz
I assume with this list these are the main power consuming parts for the build. I've currently settled with a CM 850W power supply, judging from various websites the answer seems somewhat broad. With this config would 850W be sufficient? Or should I swap out for a 1000W to be safe. I've overlooked estimated power consumption before I finalized my order. Wouldn't be a problem if i needed to swap though. All comments appreciated.
https://linustechtips.com/topic/1520027-new-build-sufficient-power/
6 hours ago, Why_Me said:
850W is fine. With that said I would go with a locked cpu for that board such as the i7 13700.
And with that a twin tower 120 to replace the AIO (AG620 ARGB is a good option for the rainbow vomits) which should get us a proper 6000/6400C34/32 kit which would be a nice frametime boost. But beyond that its a pretty good 2000 AUD Intelvidia build.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
If the PSU is Tier A or B on https://cultists.network/140/psu-tier-list/ it's fine. Otherwise I'd suggest a rethink of the model. The capacity is fine. Ideally the PSU will have native support for the 12VHPWR connector used by the GPU.
The most power hungry thing in your system is actually the CPU, not the GPU, but still 750W should be plenty for this hardware.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
