Dead as a Dodo
Solved by Sawa Takahashi,
The usual. You test with the PSU, motherboard and CPU. If you cannot get any reaction, try to remove the CPU and flash the BIOS. This board supports updating BIOS without any peripherals on it. If the board is still unresponsive and the BIOS flash isn't working, you need to RMA (or return, or exchange, at your leisure).
Good luck !
1
5
1
toxic_worper ·
11
1
voltigeurramon ·
Posted in Troubleshooting2 -
1
1
