Hey, this morning my PC gets no power after weeks of having problems on startup. The last few weeks the fans would turn on for a short amount of time and then turn off and on again while holding the power button.
I attached a video of the described behaviour. Since this morning I get no power at all.
Things I already tried:
-change the CMOS battery
-jump the power supply (did work, fans did spin and light up)
-jump the power switch pins (did not work)
-measured the power switch pins (power switch does work)
-checked the mainboard for visual damage (none found)
So now that I have ruled out the PSU or power switch I am kind of lost how to check my mainboard. What can I do the further check the system and identify the issue?
Specs:
ASRock B550 Phantom Gaming 4/ac Ryzen 5 3600XT
RTX 3070 FE
Gigabyte P750GM as PSU
https://linustechtips.com/topic/1519632-no-power-after-startup-problems/
Specs:
RTX 3070 FE
I assume you already tried the "no post guide" on the forum?
If not, try that. or start with minimum system: Only CPU, one stick of ram, GPU. No extra fans (just the AIO pump), no storge, no USB/audio header plugged in
Yes, I tried all the steps and it still won't start as a minimum system. Is there any option to check if my motherboard is dead other than checking the PSU and powerswitch?
Not without trying a known good board or try the components on a known running computer.
Also that PSU did have a voluntary recall, I hope yours isn't in the recall range. I would try a new PSU first.
  • 3 weeks later...
Hi, sorry for the delayed answer. Shortly after my post, everything started working again for half a week. Then I went back to having no power.
I got a new PSU (Cooler Master MWE 750 V2) and got my mainboard out of the case for better testing. I am now running in a weird issue:
When I connect the new PSU with the mainboard (only CPU, 1 stick of RAM and GPU) and bridge the power button pins i hear a click in the PSU and the POST-LEDs for CPU and DRAM blink for half a second. Nothing happens after. This only works once and can only be repeated after completely removing the power cable from the PSU and waiting for a bit.
When I use the cables of the new PSU with the old PSU the CPU and DRAM-LEDs blink when the mainboard is connected to power even before I bridge the power button pins. When I bridge the pins nothing happens. The CPU does not get hot. What could be the issue here?
