11 minutes ago, madonkus said:
Performance tends to be pretty good, do I need to keep an eye on anything or am I just being paranoid?
You’re good. Just make sure to clean your computer of dust periodically - your gpu in particular is a bit warm (approaching the 83c limit), so you can start to run into issues if it gets clogged with dust.
Happy computing!
Happy computing!
I'll keep an eye on it! I live in California, the room doesn't have the best airflow either so I bet that's contributing a little bit to the temp. Thanks again for everything!
That goes for everyone who helped as well!
Much love xoxoxoxoxooxox ❤️
