so i am interested in squeezing every last drop of performance out of my 2070 armor card by msi, i have downloaded a multitude of different bios but all do not work, i have even tried the oc version of the armor 2070 and that does not work, all i get are the errors "gpu mismatch" on the patched version of nvflash, can someone please help me figure this out?
https://linustechtips.com/topic/1519097-help-flashing-my-gpu/
Can't you just overclock the card?
https://linustechtips.com/topic/1519097-help-flashing-my-gpu/#findComment-16031020
5 minutes ago, Asinine- said:
i want even more performance
You likely won't get much if any due to all cards basically being voltage locked. If you want more performance, then you will be needing to mod the card with a Shunt Mod or external voltage controller being soldered on, exotic cooling solutions etc..
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1519097-help-flashing-my-gpu/#findComment-16031032
my 2070 is locked to 200w
if i could flash it i could increase that and push it further right?
https://linustechtips.com/topic/1519097-help-flashing-my-gpu/#findComment-16031033
IF you can find a compatible BIOS that allows for higher wattage, you might be able to get maybe 1 or 2% more performance, but not really worth the effort.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1519097-help-flashing-my-gpu/#findComment-16031044
that 1 or two percent is what i need, do you know where i could find a compatible one? or how to flash a different vendor card bios onto my own?
https://linustechtips.com/topic/1519097-help-flashing-my-gpu/#findComment-16032220
You're most likely going to end up with 0% performance if you keep going like this.
I get that you just want to brag that you have a faster 2070 than everyone else, but you're risking bricking your card.
And before you say you don't care, you have plenty of money, then why not by a real GPU?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1519097-help-flashing-my-gpu/#findComment-16032234
