Budget : $1000 CAD
Country: Canada
Games, programs or workloads that it will be used for: Elden Ring, Elder Scrolls, Uprising, and Diablo IV
Other details : I'm buying a cheap monitor with it I looked for the best gpu I could find for this amount but very confused how to choose my gpu anyways all help would be appreciated thx.
https://ca.pcpartpicker.com/user/GoldenFrenzy/saved/#view=R2PNpg
https://linustechtips.com/topic/1518929-first-pc-build/
6 minutes ago, GoldenFrenzy said:
Budget : $1000 CAD
Country: Canada
Your list is private
Either way I think you should go for this
PCPartPicker Part List: https://ca.pcpartpicker.com/list/2qYbnt
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($196.95 @ shopRBC)
Motherboard: ASRock B660M Pro RS Micro ATX LGA1700 Motherboard  ($89.27 @ Vuugo)
Memory: TEAMGROUP Vulcan Z 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($42.99 @ Canada Computers)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($59.75 @ Vuugo)
Video Card: ASRock Radeon RX6700XT CLD 12G Radeon RX 6700 XT 12 GB Video Card  ($459.99 @ Newegg Canada)
Case: Deepcool CH370 MicroATX Mid Tower Case  ($49.99 @ Canada Computers)
Power Supply: Thermaltake Smart BM2 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($102.25 @ Vuugo)
Total: $1001.19
Generated by PCPartPicker 2023-07-12 05:45 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1518929-first-pc-build/#findComment-16029611
Total:    $996.22
OS: OpenBSD -current WM: Polybar -- bspwm -- dmenu -- picom Components: Intel 12700KF -- G.SKILL RIPJAWS @4000 CL18 -- ASUS Dual Radeon RX 9060 XT 16GB -- ASUS ROG STRIX B760-G GAMING WIFI D4 -- JONSBO Z20 black -- ARCTIC F14 -- bequiet! SYSTEM POWER 10 550W -- DeepCool AG500BK -- Kingston Renegade G5 1TB and Samsung 9100 PRO 1TB Mouse: zalman ZM-GM7 Display panel: UltraGear 34G630A-B Headphones: Kawai SH-9 Webcam: Microsoft LifeCam HD-3000 Keyboard: HP desktop 320K Microphone: Trust GXT 259 RUDOX Camera: Fujifilm X-M5
https://linustechtips.com/topic/1518929-first-pc-build/#findComment-16029743
Included in the budget or not? With Diablo 4 in mind i think all on the tower is needed.
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($181.50 @ shopRBC)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($86.98 @ Newegg Canada)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($73.98 @ Amazon Canada)
Case: Deepcool MATREXX 55 MESH ADD-RGB 4F ATX Mid Tower Case  ($74.00 @ Vuugo)
Power Supply: Deepcool DQ750-M-V2L 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($84.88 @ Canada Computers)
Monitor: MSI Optix G2412 23.8" 1920 x 1080 170 Hz Monitor  ($159.99 @ Newegg Canada)
Total: $1181.07
Generated by PCPartPicker 2023-07-12 09:24 EDT-0400
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1518929-first-pc-build/#findComment-16029850
Total: $1181.07
I mean how about we skip diablo 4 and play path of exile instead. And how come you went for such an expensive psu and such an expensive case. Also I'm curious to know how you came to the conclusion to pick the ASRock Radeon RX6700XT CLD 12G Radeon RX 6700 XT 12 GB Video Card
16 hours ago, The Hope said:
Total:    $996.22
I'd prefer to stick with nvm m.2 if possible it doesn't seem worth it to buy a sata ssd without saving much money
Total: $1001.19
This seems like a reasonable build but why such an expensive gpu?
https://linustechtips.com/topic/1518929-first-pc-build/#findComment-16031288
Ill take that as a sarcasm rather than genuine outlook. The issue with Diablo 4 right now is the severe VRAM memory leak it has and even if you dont get it 1080p max would spike to 12GB of usage.
Those 2 are the cheapest thing id rely on in terms of power delivery and thermals respectively in Canadian market.
In my PC building, I usually work my list backwards. A lot of people start from their GPU and CPU combo (maybe case if they're looking at external aesthetics), I usually start looking for CPU that are perfect for what the system should do, and then work the supporting component. For that its simple, sort by the cheapest and then find the first thing that can do what the system need (wattage in a PSU, clearance for GPU and heatsink if air-cooled in a Case) and then weigh the quality of said part. In here I use reviews and personal accounts of current or former user.
And then finally, the GPU. Limit my price range to the rest of the budget I have, and then sort by the most expensive. From there find the most powerful GPU model you can find that isn't a scam, and run away with it. AIB does matter but really the outlier is the only one you want to watch out on for stock operation, those with the worst thermal and power delivery. If you do care for heavy tweaking because you are going to slap custom water cooling to it for example, then read individual review of the specific board you're looking at (and if you haven't, also your GPU block compatibility list), and ALSO how well it tweaks in the first place. Nvidia 4000 series for example has a pretty locked down power limit due to it being already at the edge of stability and heat output.
https://linustechtips.com/topic/1518929-first-pc-build/#findComment-16031392
It's just the issue is it costs $1300 cad even the cost for windows install, I'm looking more like $1000 cad after windows install at 1080p at 60 fps
https://linustechtips.com/topic/1518929-first-pc-build/#findComment-16031477
It's just the issue is it costs $1300 cad even the cost for windows install, I'm looking more like $1000 cad after windows install at 1080p at 60 fps or maybe I
m just being unrealistic and cut my losses at less demanding games
https://linustechtips.com/topic/1518929-first-pc-build/#findComment-16031480
12 minutes ago, GoldenFrenzy said:
There is always the option of not buying a gpu and waiting for money down the line and buying a gpu later on as I already have a gtx 750 ti for now.
I might also try the used market where you should be able to find 3080s for 500 cad
That’s just how the market is in Canada ig
Total: £1040.95
https://linustechtips.com/topic/1518929-first-pc-build/#findComment-16031556
