review build Review PC Build
Solved by Guest,
6 minutes ago, tochmoc said:Please review my build before I place an order; any suggestions will be appericated. I;m not building this for gaming or regular use. It will be for running hypervisor and about 30 40 vm on it. Thank you for any recommendation or help in advance.
GPU MSI Gaming GeForce RTX 3060 12GB CPU amd 5700g Motherboard MSI MAG X570 TOMAHAWK WIFI Memory Corsair Vengeance LPX 64GB Storage samsung pro 990 2tb Cooling/Heat Sink: Noctua NH-D15 PSU Evga 1000w
You are vastly overspending on the board, cooler and psu. With AM4 being an end of life platform I would suggest a cheaper B550 board like the B550 Aorus Elite AX. You can get a cooler such as the Thermalright Peerless Assassin 120 SE for 1/3 of the price of a D15. Also 1000W is major overkill for an 8 core cpu and RTX 3060. You would be fine with 650W. Personally I would switch the 5700G to the 5700X assuming you don't need the onboard gpu for anything ?
