My computer is old;
Operating System    Windows 10 Home 64-bit
    CPU                       Intel Core i7 4790 @ 3.60GHz    35 °C
                                  Haswell 22nm Technology
    RAM                     16.0GB Single-Channel DDR3 @ 798MHz (11-11-11-28)
    Motherboard        ASUSTeK COMPUTER INC. H87M-E (SOCKET 1150)    115 °C
    Graphics               27MP35 (1920x1080@60Hz)
                                  4095MB NVIDIA GeForce GTX 1050 Ti (EVGA)    32 °C (4 mb)
    Storage                 465GB Samsung SSD 860 EVO 500GB (SATA (SSD))    36 °C
                                  931GB Seagate ST1000DM003-1SB102 (SATA )    33 °C
                                   465GB Western Digital WDC WD5000AAKS-00TMA0 (SATA )    36 °C
    Optical Drives        HL-DT-ST DVDRAM GH24NSC0
    Audio                      Realtek High Definition Audio
I am saving for a new computer, slowly, but I am wondering if my graphics card is going. I have taken some screen shots from Fallout 4 that shows what is happening, this could be an effect that I am using the method to change the settlement size limit. Second before this problem started I had memory issues and the game crashed, removed to sticks that seemed to be the problem and the memory crash has sort of died away, down to 16mb of ram.  The problem might be retaliated to heat, I say that because it happens after playing the game for an hour?The question is the card dying or do I still hold for the next six months. I do not want to spend more then $150 Cdn if I have to get a replacement. I do have non gaming, and old, graphics cards. What is the communities opinion?
https://linustechtips.com/topic/1517591-problem-with-graphics-card/
10 minutes ago, Cathound said:
My computer is old;
I am saving for a new computer, slowly, but I am wondering if my graphics card is going. I have taken some screen shots from Fallout 4 that shows what is happening, this could be an effect that I am using the method to keep building my settlement (this is to be edit when I find the name). Second before this problem started I had memory issues and the game crashed, removed to sticks that seemed to be the problem and the memory crash has sort of died away, down to 16mb of ram.  The question is the card dying or do I still hold for the next six months. I do not want to spend more then $150 Cdn if I have to get a replacement. I do have non gaming, and old, graphics cards. What is the communities opinion?
Does it only happen in Fallout 4?  I dont really understand the problem you are having.
hat is that on your motherboard running at 115c
19 hours ago, rippy4500 said:
Also what is that on your motherboard running at 115c?
I do not know, and hwinfo states it can not guarantee the value as hwinfo does not have information about the sensor value. Thank you and thank you to all who replied.
