Will it fit?
Go to solution Solved by Paralectic,
So before I go buy my GPU I want to make myself 100% sure that the card will fit?!
My case is a Corsair Carbide 300R and the card I'm buying is the EVGA GTX 770 2GB with ACX Cooling. Will it fit is there anyone who has the same case with that card?
Any help is appreciated,
Fatal
It does, I've recently built a rig with a Carbide 300r and the exact same GPU and it fits easily with alot of headroom in terms of width.
Fatal
Case: Carbide 300R
CPU: i5 4690K @ 3.90GHz
RAM: 8GB DDR3
Mobo: MSI Z97-G45 Gaming
GPU: R9 290 Tri-X
PSU: EVGA SUPERNOVA NEX650G
Storage: 4TB NAS
Drive 1: Seagate 1TB 7200RPM
Drive 2: WD 500gb 7200RPM
___________________________
Keyboard: Vengeance K50
Headset: Vengeance 1500 V2
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/151744-will-it-fit/
Fatal
Easy, I run a 780ti in there, It can fit any length card
https://linustechtips.com/topic/151744-will-it-fit/#findComment-2026528
Okay look at this I was looking at the dimensions of the card and this is what it says? Are they dimensions correct? Also I searched your card MSI GTX 780ti and your dimensions were completely different? Here
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/151744-will-it-fit/#findComment-2026574
Fatal
ya it will fit just fine... :)
ya ur case has about 15 inc clearance for gpu and 8 inch wide...
https://linustechtips.com/topic/151744-will-it-fit/#findComment-2026575
Fatal
https://linustechtips.com/topic/151744-will-it-fit/#findComment-2026582
I am not using the reference cooler but still there is TONS of room in the 300r for a GPU, i dont think there is a card that will not fit
https://linustechtips.com/topic/151744-will-it-fit/#findComment-2026587
Alrighty thanks :D
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/151744-will-it-fit/#findComment-2026612
Alrighty thanks :D
Here are 2 pictures of the EVGA GeForce GTX 770 SC with ACX cooler in a Corsair Carbide 300r ( I've built this PC last month for a friend of mine )
( I did a pretty good job on the build in my opinion :D )
( Note: The RAM is in Dual Channel, in this picture it's not lol )
https://linustechtips.com/topic/151744-will-it-fit/#findComment-2026636
Nice :D What ram is it?
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/151744-will-it-fit/#findComment-2027440
