Budget (including currency): $1000
Country: USA
Games, programs or workloads that it will be used for: new spiderman game, god of war, modern games that i can play at 1080-1440p
Other details ):
this current build only costst about 1000 dollars but i want to see if theres anything i could imrpove, and most importantly, Im wondering if theres anything i could do to lower the price of the build by 60 bucks (so i have enough money to buy a monitor).
my current build:
Component   Selection
CPU   AMD Ryzen 5 7600 3.8 GHz 6-Core Processor AMD Ryzen 5 7600 3.8 GHz 6-Core Processor $216.28   amazon-prime.png     $216.28 logo2_merchant_amazon.png Buy
CPU Cooler   Thermalright Peerless Assassin 66.17 CFM CPU Cooler Thermalright Peerless Assassin 66.17 CFM CPU Cooler $54.90   amazon-prime.png     $54.90 logo2_merchant_amazon.png Buy
Motherboard   Gigabyte B650M K Micro ATX AM5 Motherboard Gigabyte B650M K Micro ATX AM5 Motherboard
From parametric filter:
  • Form Factor: ATX, Micro ATX
  • Chipset: AMD B650
  • Memory Slots: 4 - 16
$119.99   FREE     $119.99 logo2_merchant_newegg.png Buy
Memory   TEAMGROUP Elite 16 GB (2 x 8 GB) DDR5-4800 CL40 Memory TEAMGROUP Elite 16 GB (2 x 8 GB) DDR5-4800 CL40 Memory
  • Form Factor: 288-pin DIMM (DDR5)
  • Type: DDR5
  • Modules: 2 x 8GB
$35.99   amazon-prime.png     $35.99 logo2_merchant_amazon.png Buy
     Add Additional Memory
Storage   Leven JPS600 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive Leven JPS600 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
  • Capacity: 960 GB - 15360 GB
  • Type: SSD
  • NVME: Yes
$34.99   amazon-prime.png     $34.99 logo2_merchant_amazon.png Buy
     Add Additional Storage
Video Card   Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card
  • Chipset: Radeon RX 6700 XT
  • Cooling: 2 Fans, 3 Fans, 120 mm Radiator, 120 mm Radiator + 1 Fan, 120 mm Radiator + 2 Fans, 240 mm Radiator, 240 mm Radiator + 1 Fan
$354.00         $354.00 logo2_merchant_amazon.png Buy
     Add Another Video Card
Case   Phanteks Eclipse G360A ATX Mid Tower Case Phanteks Eclipse G360A ATX Mid Tower Case $89.99   $9.99     $99.98 logo2_merchant_amazon.png Buy
Power Supply   Thermaltake Toughpower GX2 600 W 80+ Gold Certified ATX Power Supply Thermaltake Toughpower GX2 600 W 80+ Gold Certified ATX Power Supply
https://linustechtips.com/topic/1517346-help-for-my-build/
Well you could go intel and get a 12400f instead so go for either this
PCPartPicker Part List: https://pcpartpicker.com/list/t23Gv3
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($149.99 @ Amazon)
Motherboard: Gigabyte B660M DS3H AX DDR4 Micro ATX LGA1700 Motherboard  ($129.99 @ Newegg)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($32.97 @ Newegg)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($54.99 @ Amazon)
Video Card: Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card  ($354.00 @ Amazon)
Case: DIYPC F2 MicroATX Mini Tower Case  ($44.98 @ Newegg)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Monitor: Gigabyte G27Q 27.0" 2560 x 1440 144 Hz Monitor  ($239.99 @ Newegg)
Total: $1106.90
Generated by PCPartPicker 2023-07-04 14:35 EDT-0400
but if you want an am5 build your gonna have to go down to 75hz
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1517346-help-for-my-build/#findComment-16018415
Country: USA
Other details😞
my current build:
Component   Selection
  • Chipset: AMD B650
  • Type: DDR5
  • Modules: 2 x 8GB
  • Type: SSD
  • NVME: Yes
The Ryzen 7600 non X actually comes with a stock cooler and is adequate to cool the 7600.  So you can save the money from buying a cooler to get a monitor 🙂
You can always upgrade the CPU cooler later but it will work totally fine out of the box with the stock cooler.
Maybe get some faster ram like 5600mhz cl36.
https://linustechtips.com/topic/1517346-help-for-my-build/#findComment-16018417
Just now, Hinjima said:
What do you mean by this?
For the monitor as if they will want to fit one in here they will have to go down from 1440p 144hz to 1440p 75hz
Total: £1040.95
https://linustechtips.com/topic/1517346-help-for-my-build/#findComment-16018422
1 minute ago, Hinjima said:
The 7600 comes with a stock cooler so he can save the 55 bucks on not getting a cooler.
Plus AM5 has more upgrade path than LGA1700... I'd go 7600
https://linustechtips.com/topic/1517346-help-for-my-build/#findComment-16018431
Total: $1106.90
@mattat for am5 get this build
PCPartPicker Part List: https://pcpartpicker.com/list/hyXzmr
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($216.28 @ Amazon)
Motherboard: ASRock A620M-HDV/M.2+ Micro ATX AM5 Motherboard  ($95.99 @ Newegg)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($109.99 @ Amazon)
Power Supply: Thermaltake Toughpower GX2 600 W 80+ Gold Certified ATX Power Supply  ($66.98 @ Amazon)
Monitor: Acer KA272U biipx 27.0" 2560 x 1440 75 Hz Monitor  ($149.99 @ Amazon)
Total: $1093.20
Generated by PCPartPicker 2023-07-04 14:43 EDT-0400
Total: £1040.95
https://linustechtips.com/topic/1517346-help-for-my-build/#findComment-16018434
Total: $1093.20
ive updated to
https://linustechtips.com/topic/1517346-help-for-my-build/#findComment-16018520
Just now, mattat said:
ive updated to
Just go with my build as that mobo, ram and ssd is pretty bad
Total: £1040.95
https://linustechtips.com/topic/1517346-help-for-my-build/#findComment-16018521
