12vhp cable Adapter plugging question ?
Solved by Agall,
4 minutes ago, CasoF13 said:thx but for the time being i stay with the psu
An 850W is perfectly fine, even if you need to only use 2 cables daisy chained. Just be weary trying heavy overclocks like what I run since that will regularly draw +550W alone. I started with my RM1000x and two daisy chained cables, added a 3rd just to be safe like 3 weeks into the same overclock.
