2080 Super Overheating issues
Go to solution Solved by Mark Kaine,
7 hours ago, Cornflake said:
"The card and case are clean. I have exchanged the thermal paste of the card before. I found it was very dried out, and changing actually fixed it for about 1 month before it was back to its loud old self."
In terms of liquid metal, would it break the card immediately or just not be good for longevity?
yeah, typically its an issue for longevity (but it can just randomly spill and damage  something too....) also if your cooler is aluminum for example its not even an option (lm destroys aluminum very quickly)
Hi, long time viewer first time poster.
Ive had a Gigabyte 2080 Super Windforce OC for about 3 years now. The card doesn't thermal throttle, though it does get VERY loud frequently. The fans seem to jump from about 60-70% to 100% for a minute and back down. Here's some information about my system and ideas to fix it, it would help me a lot to get some opinions on this.
The card was originally in a mid tower with a glass panel, and has now been moved into a ITX case (with good airflow, the Hyte revolt 3) With the switch I also changed from Intel to Amd.
The card and case are clean. I have exchanged the thermal paste of the card before. I found it was very dried out, and changing actually fixed it for about 1 month before it was back to its loud old self. Here's some system specs:
Ryzen 5 7600
2080 Super
16gb DDR5
Asus Strixs ITX mobo
Windows 11
I feel like the card runs hotter because of some manufacturers defect, I got it new but discounted on ebay.
I've thought about 1. liquid metal instead of the thermal paste to fix the drying out issue, and 2. deshrouding it and putting on 2 be quiet case fans. The visuals of the card aren't important, and voiding the warranty doesn't matter since its run out anyways.
Thank you for any and all help. :)
https://linustechtips.com/topic/1516956-2080-super-overheating-issues/
even if you did have a warranty, you would have to take off the back screws for the heatsink to void it. But since you've already done that it's not a problem
is this just normally?/starting up?/in game?
Also how are the temps?
I might try and tune the fan curve in msi afterburner first and go from there
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
The happens in game, though the title doesn't have to be very demanding for it to 100%.
At 60% Utilisation for about a hour of playing, it's hovering between 80-85 °C
5 hours ago, Mark Kaine said:
did u replace the thermal paste yet, yes or no?
Also *do not* use liquid metal for gpus
Ryzen 5 7600
2080 Super
16gb DDR5
Windows 11
Thank you for any and all help. 🙂
its a gigabyte issue with the hotspot (some other ones as well)
your temps might seem fine but you should check the hotspot temp. I had the exact same issue with my gigabyte 2070s. it is now in my partners pc and i fixed it by simply reducing the power draw of the card to 90% she didnt lose any perf but the gpu hotspot temp does not get anywhere close to cause these rampid fan speed ups. which would usually happen if i remember correctly at 105 degrees on the hotspot. i could repaste it but for now it doesnt seem necessary.
PC:
MSI MPG X870E CARBON WIFI                            (motherboard)  |    Powercolor RX 9070XT Red Devil    (Gpu)
ryzen 7 9800X3D        (cpu)   |   2560x1440 165hz (phillips 27m1c5500v)    (Monitor)
ARCTIC Liquid Freezer III Pro A-RGB 420                (cpu cooler)  |  seasonic focus plus gold 850w      (Psu)
Lian Li O11 Dynamic EVO XL                                         (PCcase)    |  Kingston FURY Beast RGB 32 GB (2 x 16 GB) DDR5-6000 CL30   (Memory)
Steel series apex pro                                                  (keyboard)   |   Razer Basilisk v3 pro    (mouse)
https://pcpartpicker.com/user/hollyh888/saved/LX2cYJ
-Scott Manley, 2021
Alright that makes sense, and I would do this by undervolting in msi afterburner for example?
Ops I didn't mean to mark that as solved. But okay no liquid metal. I used thermal grizzly when I repasted. Any other pastes more resistant to dry out?
i use mx4, should last a long time and is reliable
-Scott Manley, 2021
yes you can do that or the easy way is to simply drag the power slider down per 5 untill under load it doesnt happen anymore. than fine tune it and your done. Combining it with the uv might show better results.
im guessing you know how the uv works and what the most simple way to do it in afterburner is?
if not here is a video you can follow that shows you how to do it easily.:
but do make sure via hwinfo that it is indeed the hotspot thats causing the issue. just in case 🙂
PC:
