It's fine, don't worry about it. What matters is which temps you get after a while under load.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/1516932-cpu-temps/#findComment-16015534
4 minutes ago, Whatisthis said:
The x3d chips run hot because of the cache stacked on top of the cores. More material for the heat to run through.
what kind of temps do you get when you run cinebench r23 multicore bench?
Haven’t ran any bench marks and don’t know how this is my first build. Just finished building early morning after hours of work. How would I run bench marks?
https://linustechtips.com/topic/1516932-cpu-temps/#findComment-16015544
You download your program of choice and run it. It's as simple as that.
I personally like Prime95 on the Small FFT preset. If your temps are good on that, you can bet your jimmies that it'll be fine for anything else you'll ever face.
https://linustechtips.com/topic/1516932-cpu-temps/#findComment-16015565
With Cinnebench R23. NZXT CAM also tends to not be completely accurate. Use GPU-Z for the graphics card and HWinfo for everything else.
https://www.techspot.com/downloads/6709-cinebench.html
https://www.hwinfo.com/download/
https://www.techpowerup.com/gpuz/
Cinnebench isn't going to test your graphics card, just the CPU so don't expect to see the gpu go up in temps while you're running Cinnebench.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1516932-cpu-temps/#findComment-16015567
On Cinebench the highest I saw was 82 degrees is that good?
https://linustechtips.com/topic/1516932-cpu-temps/#findComment-16015728
Yes
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1516932-cpu-temps/#findComment-16015743
