Could you give me some feedback about my loop please? I really need an experienced person to rate it. This is my 1st time water cooling a pc. I have developed 2 big leaks because the fittings weren't tight enough. It's all ogre now.
post-54843-0-27161100-1399980321_thumb.j
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/151674-thoughts-about-my-loop/
put a exhaust fan it
Specs
https://linustechtips.com/topic/151674-thoughts-about-my-loop/#findComment-2025603
I will, I put it out because it was in the way.
IT'S YELLOW!
Really? I don't even know why I went with yellow. No one goes with yellow tbh
COOLING:
https://linustechtips.com/topic/151674-thoughts-about-my-loop/#findComment-2025609
nothing goes with yellow orly?
Specs
https://linustechtips.com/topic/151674-thoughts-about-my-loop/#findComment-2025621
Um, I may get that.
COOLING:
https://linustechtips.com/topic/151674-thoughts-about-my-loop/#findComment-2025651
Yellow is a really cool color. Looks great. Would look even better with that mobo.
I should be studying.
https://linustechtips.com/topic/151674-thoughts-about-my-loop/#findComment-2025733
