Mic volume suddenly randomly low despite doing nothing
Solved by Bombastinator,
40 minutes ago, Elijah Kamski said:I tested it with the Vive Cosmos disconnected and it still had the same issue, I also reinstalled the audio drivers from Asus's website for my mobo using DDU (yes it has that function) and it did not work.
I only have the KRK KNS 6400 headphones connected, it is connected to the phones output on the mixer. I have the headphone output from the desktop connected to the mixer as well so I can hear everything.
A mixer? Like the old style ones with all the sliders? Those things are easy to knock the volume on.
