I was building my first pc and when I connected my monitor to my graphics card, it gave a “No Signal” message and my keyboard wouldn’t turn on. I tried unplugging everything, checking the psu, but nothing worked. The power supply does work, but I’m not sure if it can’t connect to the motherboard, since mine doesn’t have Q-LED cores.
Can anyone help?
https://linustechtips.com/topic/1516249-pc-not-powering-on/
5 hours ago, Arcc0n said:
After realizing that i needed to connect the motherboard to the case, I finally got the PC to work but my monitor says “no signal” when i connect it to the computer. My PC does work with a TV, but both of the acer monitor i have tried do not work.
You need to plug your HDMI/DPI cable to your graphics card, not motherboard. You need to connect cable prior to powering up the system.
GPU : RTX 3070 Gaming X TRIO | CPU : Ryzen 5 7600 \ COOLER : Deepcool AK620 | MOBO : ASUS TUF Gaming B650 Plus | RAM : Corsair Vengeance RGB DDR5 16GBx2 6200 MHz \ Storage : Samsung 970 EVO Plus M.2 1TB \ PSU : Corsair TX750M | CASE : Be Quite! Pure Base 500DX Black
https://linustechtips.com/topic/1516249-pc-not-powering-on/#findComment-16017796
