Budget intel build help
Go to solution Solved by SorryBella,
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($198.88 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($42.90 @ Amazon)
Motherboard: Gigabyte B660M AORUS Pro AX DDR4 Micro ATX LGA1700 Motherboard  ($109.99 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($48.97 @ Amazon)
Storage: TEAMGROUP MP33 PRO 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($72.98 @ Amazon)
Video Card: ASRock Challenger D Radeon RX 6600 8 GB Video Card  ($179.99 @ Newegg)
Case: Montech X3 Mesh ATX Mid Tower Case  ($59.99 @ Newegg Sellers)
Power Supply: FSP Group Hydro G Pro 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($85.99 @ Newegg Sellers)
Total: $799.69
Generated by PCPartPicker 2023-06-28 14:05 EDT-0400
Budget (including currency): $800 USD
Country: USA
Games, programs or workloads that it will be used for: Minecraft, Forza Horizon 5, Game Development, and 3d Modeling (not super important).
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I just need a parts list that follow this, I am hoping to run these things smoothly without choppy/laggy experiences. As well, I need at least 16gb of RAM.
EDIT: I don’t really want anything RGB
https://linustechtips.com/topic/1516152-budget-intel-build-help/
Total: $799.69
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Total: $799.69
Is there an NVIDIA GPU that can fit this list? (based off of what you gave me but a bit edited) https://pcpartpicker.com/user/WoodsMc/saved/#view=Z2sxf7
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($149.99 @ Amazon)
CPU Cooler: *Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler  ($19.89 @ Amazon)
Motherboard: *Gigabyte B660M AORUS Pro AX DDR4 Micro ATX LGA1700 Motherboard  ($109.99 @ Newegg)
Storage: *Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($49.99 @ Amazon)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 3060 12GB 12 GB Video Card  ($269.99 @ Newegg)
Case: *Fractal Design Pop Air ATX Mid Tower Case  ($79.99 @ B&H)
Power Supply: *FSP Group Hydro G Pro 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($85.99 @ Newegg Sellers)
Total: $814.80
Generated by PCPartPicker 2023-06-28 14:24 EDT-0400
Alternative would be look second hand for a Nvidia GPU if you want one, you could get some mid range 20 series or maybe high end 10 series for about the price as some others have quoted here.
How is the performance of the RTX 3050? EDIT: or the 1050 Ti?
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($197.89 @ Amazon)
CPU Cooler: Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler  ($19.89 @ Amazon)
Motherboard: Gigabyte B660M DS3H AX DDR4 Micro ATX LGA1700 Motherboard  ($99.99 @ Newegg)
Memory: TEAMGROUP T-Create Expert 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($30.99 @ Amazon)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($54.99 @ Amazon)
Video Card: ASRock Steel Legend OC Radeon RX 6650 XT 8 GB Video Card  ($239.99 @ Newegg)
Case: Deepcool MACUBE 110 MicroATX Mini Tower Case  ($49.99 @ Newegg)
Total: $779.72
Generated by PCPartPicker 2023-06-28 17:04 EDT-0400
But i'd recommend if you can stretch the budget by some $40 to $840, get a
ASRock Challenger D OC Radeon RX 6700 XT 12 GB Video Card
because for $309 it's basically a 4060Ti with more VRAM and $100 less.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
I mean 3050 is better for sure, just depends on price.  If they are the same price then for sure get a 3050.
For comparison I would pay about 50% more for a 3050 over 1050Ti.  (EX 1050Ti is $100, I would be willing to spend $150 on a 3050 as it will probably be worth it)
