Possible Upgrade? Will it work?
40 minutes ago, Nightmarecast said:Budget (including currency): 500.00
Country: USA
Games, programs or workloads that it will be used for: Starfield, Mortal Kombat 1, General Gaming
My current build:
CPU - Ryzen 2600x
GPU - GTX 1080ti Aorus
Ram - 32GB DDR4 3200
Motherboard - ASRock 370 Pro 4
Power Supply - 750 watt non plus power supply
Monitor - 32 inch 1440p monitor
Build Upgrade:
CPU - Ryzen 3800x
Motherboard - MSI MAG B550 Tomahawk Gaming Motherboard
Will these changes work? Are they worth it? Thanks for any help on the situation, all help will be considered.
Do what others are saying and get like a 5800x3d. You should be able to get $180-$200 from selling those two things which makes the budget $700.
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor ($289.27 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler ($37.90 @ Amazon)
Video Card: ASRock Challenger Pro OC Radeon RX 6750 XT 12 GB Video Card ($349.99 @ Newegg)
Total: $677.16
Generated by PCPartPicker 2023-06-26 19:10 EDT-0400
Then you could do this, upgrade to a 5800x3d, get a cooler and a 6750 XT which outperforms the 1080 ti
