Possible Static Electricity Damage?
4 minutes ago, Zer0BL2 said:I recently built a new PC with a fresh install of Windows 11 and after it was all set up and I was just putting the side panel on, I saw and heard static electricity at the corner of my case and my monitors went black while all the lights on all of the internal components stayed on. I turned the PSU off and waited a couple seconds before unplugging it and plugging it back into the wall. The PC turns on just fine but I’m getting occasional crashes to desktop in some games (RDR2 and Lego Journey) and a weird visual glitch that looks like a permanent screen tear about 1/4 of the way down the monitor only in cutscenes in Control. Could this be possibly a result of the static electricity discharge? Or am I just being paranoid?
OS: Windows 11 Pro 64 bit
Specs:
CPU: Ryzen 7 7800X3D
GPU: MSI RTX 4080 Suprim X
Mobo: Gigabyte x670 Aorus Elite AX (bios version f10a)
RAM: 32gb (16x2) C30 6000mhz G.Skill Trident Z5 Neo RGB with EXPO enabled
PSU: Corsair RM1000x (1000 watts)
Storage: WD_Black SN850x 1tb M.2 SSD
It shouldn't cause by just the shock you seen and heard. Because by the time you are closing the panel, I assume you already plugged the ground, most of the charges goes straight to the ground.
I would suspect software corruption first
It's possible that the protection triggered by the shock also corrupted system files/drivers. So try restore DISM image and do a SFC /scannow
See this Microsoft guide
Also check your Event Viewer to see if there are any logged error messages. You can disregard most warning and information messages but you should look for Critical or Error messages.
I'm not ruling out something gets damaged by static shock, but both LTT and Elctroboom had made video to calm our nerves on static shock.
