ATT Fiber stuck on 100mbps for 1 ethernet device?
Solved by Biohazard777,
2 minutes ago, Optane^ said:It's like it can only handle 1 1gig connect at a time.
Does your bedroom ever get 1 Gb/s?
I mean, have you tried unplugging the device in the office and observed that your bedroom PC gets 1 Gb/s?
I doubt that is happening.
4 minutes ago, Optane^ said:Changing ports doesn't matter.
Any ideas?
My bet would be: bad ethernet cable.
Change the ethernet cable running to your bedroom, or redo the connectors (re-crimp the RJ-45s on both ends).
