read the title for them....
yes
Specs
https://linustechtips.com/topic/151553-are-these-the-same-thing/#findComment-2023838
yes
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/151553-are-these-the-same-thing/#findComment-2023852
I'd say no and here's reason why. First one is builders OEM. It will most definetly be bound to first mobo its installed. Second one doesn't really have lisence infos up but I'd assume its normal OEM which can be transferred with bit tweaking.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/151553-are-these-the-same-thing/#findComment-2025013
