No Post system
Got it working....
But the damnedest thing happened. I hooked up the new power supply and the thing turned on!
BUT...
As soon as it came on I saw a flash of blue sparks and smoke came out of the motherboard.
The spark came from right here shown inside red circle on photo.
So I looked closely at the area and saw a tiny spec of something. Used a q-tip to brush it out. I don't think this was the cause of the original problem because while I had the thing apart I cleaned and blew out the PC thoroughly. But I suppose it could have been there all along causing a problem. Powered on the PC again and it still worked. Seemed to boot fine. But still needed to add in my heatsink and monitor.
Now the really weird part. Out of curiosity, I removed the new PSU connections and plugged in my old PSU since the cables were all still there. And it booted up with the old PSU! Magic smoke indeed! So I buttoned everything up and connected display and keyboard/mouse. Booted right into the OS. I am typing on the PC now. Everything seems fine as far as memory is showing properly and storage devices. And the cpu fans that are connected adjacent to the spark area. Will run some stress tests to see if any issues crop up. I feel lucky. And might just keep this new PSU on hand for future troubleshooting.
