Budget (including currency): £1600
Country: uk
Games, programs or workloads that it will be used for: general gaming at 1440p
Other details:
the gpu has a note about certain connections but I’m not entirely sure what it’s about
also just want a simple overview to see if it’s good.
I know it’s a more expensive case but i quite like it.
also how do I find used GPU’s on part picker
https://uk.pcpartpicker.com/list/TQsFFg
https://linustechtips.com/topic/1515111-need-help/
The parts list is se tot private.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1515111-need-help/#findComment-16001782
Country: uk
Other details: the gpu has a note about certain connections but I’m not entirely sure what it’s about
I know it’s more expensive case but o quite like it.
https://uk.pcpartpicker.com/user/Isaacrimmer231/saved/9WcFP6
The parts list is private, change it and post again 🙂
https://linustechtips.com/topic/1515111-need-help/#findComment-16001783
I would run that build like this.
PCPartPicker Part List
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  (£274.88 @ Amazon UK)
CPU Cooler: Thermalright Peerless Assassin 120 SE WHITE ARGB 66.17 CFM CPU Cooler  (£45.00 @ Computer Orbit)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard  (£139.99 @ Amazon UK)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  (£71.99 @ Scan.co.uk)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£95.00 @ Amazon UK)
Video Card: *PNY XLR8 Gaming VERTO EPIC-X RGB GeForce RTX 4070 Ti 12 GB Video Card  (£770.13 @ Amazon UK)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  (£114.95 @ AWD-IT)
Power Supply: NZXT C850 (2022) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£106.00 @ MoreCoCo)
Total: £1617.94
Generated by PCPartPicker 2023-06-23 19:39 BST+0100
A better look at that board and case.
https://www.msi.com/Motherboard/PRO-B760-P-WIFI-DDR4
https://lian-li.com/product/lancool-216/
https://linustechtips.com/topic/1515111-need-help/#findComment-16001811
https://uk.pcpartpicker.com/list/nDXtVw
7900x + 3090 + 32gb 5600c30
Used gpu so make sure you can return incase faulty, 24gb of vram so should have no issues at 1440p or 4k even in the coming years unlike 12gb or possibly even 16gb cards. Otherwise you can substitute for a 6900/6950xt if you wanna buy new
7900x is abit overkill so you may wanna get a 7700x instead
https://linustechtips.com/topic/1515111-need-help/#findComment-16001825
How do you search for used gpus on part picker
https://linustechtips.com/topic/1515111-need-help/#findComment-16001860
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  (£294.89 @ Amazon UK)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (£44.90 @ Amazon UK)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  (£130.56 @ Amazon UK)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£126.64 @ Amazon UK)
Storage: TEAMGROUP MP33 PRO 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£75.70 @ Amazon UK)
Video Card: XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card  (£764.79 @ Amazon UK)
Case: Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case  (£69.98 @ Amazon UK)
Power Supply: SeaSonic G12 GC 850 W 80+ Gold Certified ATX Power Supply  (£99.89 @ Amazon UK)
Total: £1607.35
Generated by PCPartPicker 2023-06-24 07:23 BST+0100
All AMD version.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1515111-need-help/#findComment-16002418
