Help with Realtek drivers
Go to solution Solved by 191x7,
I update my Realtek drivers (network and sound) using Iobit Driver Booster. Might I recommend you do the same?
Ok so, I was trying to update my realtek drivers and then an error popped up and insta crashed. Then i had to restart my pc, and 1)My headset and Mic doesn't work 2)I now can't find my headset's mic on the sounds tab.
Btw I tried reinstalling the drivers like 3 times but it would just not work
pls help 😞
https://linustechtips.com/topic/1515012-help-with-realtek-drivers/
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Just now, dimitrisk said:
Ok, but where do I download it from, there are multiple websites and most are copies
From the official page https://www.iobit.com/en/driver-booster.php
1 minute ago, dimitrisk said:
thanks, i will try to keep you updated
watch out with instalation
iobit likes to install major bloatware in the install screen
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
yeah it installed like 2 more apps without consent even though I actually need one of them💀 I deleted the other one
i mean it was with ur consent
if u didnt rush through the install screens theres checkboxes to not install it
thats on u bro, u technicaly consented bc u werent carefull
Setup:
Did it solve your issue?
I think it was included in the privacy policy but hey it actually ended up being kinda useful
nah its litterayl when u instal it
it says "install iobit advanced systemcare" witcha  checkbox next to it
same as avast
Setup:
fr? I didn't notice, Anyway, It works perfectly! Thanks y'all
remember to marlk as solution then
Setup:
