does anyone know how I can prevent that the RGB lighting of my Ram (Dominator Platinum RGB) my mouse (Saber RGB Pro) and my keyboard (K70 RGB TKL) can not be controlled by iCUE, or only everything that is  the special LEDs (function keys), but only light up red. I have already tried to reinstall the firmware and restart the PC but that brings nothing.
https://linustechtips.com/topic/1514897-icue-does-not-work/
ICUe is kinda crappy bloatware, use SignalRGB
https://linustechtips.com/topic/1514897-icue-does-not-work/#findComment-16000002
or an open source alternative.
ask me about my homelab
https://linustechtips.com/topic/1514897-icue-does-not-work/#findComment-16000051
does anyone have an idea if one of the ser Obzionen offers the possibility to use an arduino as RGB controller because I need this function
https://linustechtips.com/topic/1514897-icue-does-not-work/#findComment-16000082
2 minutes ago, NorKris said:
icue was rated to be better by derbauer  and his viewers 😛
I absolutely hated it, plus it's really sketchy with low level access, it even takes a couple reboots to get rid of 😞
https://linustechtips.com/topic/1514897-icue-does-not-work/#findComment-16000303
hah, i use it for Temps, fans and RGB 🙂
signal RGB or open RGB never finds all the stuff i got.
u wanna know a rly rly bad one?  Logitech G hub, when i got a new keyboard that req'd it, it moved my mouse over to G hub, deleted all its settings and macros on it but, it left behind my gamepad (g13) in the old software 🤣
https://linustechtips.com/topic/1514897-icue-does-not-work/#findComment-16000314
I use FanControl for fans, temps are monitored by HWInfo64
I also use G Hub cause I got Logitech KB+M, it don't has many features but it's light and unintrusive, whereas iCUE was a complete mess advertised to do lot of stuff but nothing was clear, the UI was atrocious
https://linustechtips.com/topic/1514897-icue-does-not-work/#findComment-16000319
Oh yeah thats common thread. G27, G710+, older Romer G line is also abandoned and has no G Hub support. Its outright planned obsolescence.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1514897-icue-does-not-work/#findComment-16000782
so stupid lol, i ended up removing g hub and had to delete stuff in reg edit to get my mouse back in the old software
https://linustechtips.com/topic/1514897-icue-does-not-work/#findComment-16000807
