Budget (including currency): 500-600$ usd
Country: USA
Games, programs or workloads that it will be used for: Mainly games atm and some cybersecurity workloads
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://pcpartpicker.com/user/leastt/saved/f39tCJ current parts list, I'm not sure what else I need besides a gpu, pc case, and power supply I just don't know what to get.
https://linustechtips.com/topic/1514811-my-first-build/
9 minutes ago, kezpiar said:
You need an integrated graphics to initially boot a Ryzen system. You cant do this build.
PCPartPicker Part List
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core Processor  ($91.14 @ Amazon)
Motherboard: ASRock B550M PG RIPTIDE Micro ATX AM4 Motherboard  ($104.99 @ Newegg)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($48.99 @ Amazon)
Storage: TEAMGROUP MP33 PRO 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($41.99 @ Amazon)
Video Card: ASRock Challenger D Radeon RX 6600 8 GB Video Card  ($179.99 @ Newegg)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case  ($49.99 @ Amazon)
Power Supply: Corsair CX650M (2021) 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($79.99 @ B&H)
Total: $597.08
Generated by PCPartPicker 2023-06-22 10:45 EDT-0400
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1514811-my-first-build/#findComment-15999709
Total: $597.08
oh Ik i need graphics to like boot the build up but i still havent built it thats the thing i just need the gpu, power supply and the case i'm just tryna figure out what to pair w the ryzen 7 3700x
https://linustechtips.com/topic/1514811-my-first-build/#findComment-15999718
So youve owned all the part in the listing or what?
https://linustechtips.com/topic/1514811-my-first-build/#findComment-15999775
22 minutes ago, kezpiar said:
yes i have all the stuff in the list
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($181.99 @ Newegg)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  (Purchased For $0.00)
Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) ATX AM4 Motherboard  (Purchased For $0.00)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  (Purchased For $0.00)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($41.99 @ Amazon)
Storage: Western Digital Black SN750 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (Purchased For $0.00)
Video Card: ASRock Challenger D OC Radeon RX 6700 XT 12 GB Video Card  ($309.99 @ Newegg)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($79.99 @ B&H)
Power Supply: Deepcool PM850D 850 W 80+ Gold Certified ATX Power Supply  ($107.18 @ Amazon)
Total: $721.14
Generated by PCPartPicker 2023-06-22 11:53 EDT-0400
Included a quick and dirty CPU upgrade, you can flip that 3700X off for 90-100$ to cover the overbudget.
https://linustechtips.com/topic/1514811-my-first-build/#findComment-15999818
Total: $721.14
bett and thank you i appreciate it ill start looking into grabbing that
https://linustechtips.com/topic/1514811-my-first-build/#findComment-15999854
