Budget (including currency): $2550
Country:
Games, programs or workloads that it will be used for: Every day use
What do you think about my build
It is my first pc build
I am worried if i choose the correct parts
I am planning to start order the parts next week
https://linustechtips.com/topic/1514794-my-first-pc-build/
i9 for everyday use? Seems a bit overkill, extremely overkill at that.
Give us more use cases. We can probs slash half the price of your current configuration and still have it do everything you want.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1514794-my-first-pc-build/#findComment-15999183
Country:
You don't need an i9 for everyday browsing! What do you mean by everyday browsing? Also that ram isnt the best and you can get better, don't buy a Corsair RM850x, there are much cheaper but still good Power Supplies. If your just doing gaming and web browsing and stuff a 7800x3d would be a good CPU because that is one of the best CPU's for gaming nowadays. Also get a cheaper cooler like the Thermalright Peerless Assasin 120 SE. Also buy a cheaper motherboard? Do you really need a Z790? If your going AMD cpu side get a B650 or a B650E.
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
https://linustechtips.com/topic/1514794-my-first-pc-build/#findComment-15999202
As i said it is my first time building so I not that good in pc parts
Basically what i meant by everyday use is like gaming at best graphics possible, maybe even streaming, doing school stuff, etc
Lets say i change my RAM to ADATA XPG Lancer DDR5 6000Mhz can you recommend so some PSU,  CPU COOLERS instead of what i choose
Also if take a 7800x3d should i keep my rx 7900 xtx or?
https://linustechtips.com/topic/1514794-my-first-pc-build/#findComment-16001894
Can you like send some ideas man
You said you can slash the price right, like how, what do you recommend changing and to what
https://linustechtips.com/topic/1514794-my-first-pc-build/#findComment-16001903
Tried to be unique with case and fan selection. Could save a bit I guess if you went with a stereotypical case design. Some $1000 under and should still be plenty of kick. This is US list so Azerbaijan will probs have higher prices and less selection meaning you'll be spending more than the $1600~ for light stuff this will do circles around your games, streaming and school work. In theory you could get a 7900XT to get AV1 encode for better streaming but unless streaming is your full time thing where viewers demand the best quality footage, I don't think you're missing out on that much.
PCPartPicker Part List
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($289.99 @ B&H)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($69.98 @ Amazon)
Motherboard: ASRock B760 Pro RS ATX LGA1700 Motherboard  ($139.99 @ Newegg)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  ($104.99 @ Newegg)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($117.00 @ Newegg)
Video Card: PowerColor Red Devil OC Radeon RX 6950 XT 16 GB Video Card  ($629.99 @ Amazon)
Case: Lian Li O11 Dynamic Mini Snow Edition ATX Mid Tower Case  ($114.99 @ B&H)
Power Supply: Cooler Master V850 SFX GOLD 850 W 80+ Gold Certified Fully Modular SFX Power Supply  ($149.99 @ B&H)
Case Fan: Phanteks D30-120 Reversed 61.5 CFM 120 mm Fan  ($39.99 @ Newegg)
Total: $1696.90
Generated by PCPartPicker 2023-06-25 05:03 EDT-0400
https://linustechtips.com/topic/1514794-my-first-pc-build/#findComment-16003824
With current intel it doesn't matter if you shoot for the stars with 13900k or spend reasonably for 13600 - you are gonna get the same gaming performance, which is about the same as Ryzen 7700X. Sorry dude, that's the way it is. Old Gen vs New Gen you just can't fight with the efficiency and now weirdly even cost. What i'm also like 86.5% sure is that this furnace disguised as a CPU, the 13900k, would most likely fry a "cheap" $250 board. Just 16x 70A power stages in 8+8 config, not gonna survive for long with a CPU which easily can drain 300W on its own. I guess the back of that PCB would be going close to 95-100°C with that CPU under load. If you wanna stick to intel, it's really better to dial down to a 13600 or 13700k if it's on sale. The least money you pour into a dead platform, the better, because the way it looks, in less than 2 years you might wanna switch platforms again.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1514794-my-first-pc-build/#findComment-16003853
