Big oof, help please
Solved by Hinjima,
2 minutes ago, PKYgames said:So, I was updating the BIOS for my computer and now it just keeps resetting.
HP 400 g3 minitower
i5-6500 processor
H110 motherboard
It would boot before, but for some reason it would not display the post menu at startup and every time I tried pressing esc or f10 it would reset, but if I did nothing it loaded win 10. Any suggestions?
If your motherboard has a CMOS battery ( silver round battery )
Remove it for 5 minutes and try again.
